Just wondering how far you guys are getting on a full tank? im only geting around 250 kms from a full tank of 91 or 96 what about you?
its a 94 1.6 vitara fuel injected surely I should be getting more than this?
vitara fuel economy
- al889
- Driver/Navigator
Re: vitara fuel economy
That sounds way off, I get 500+ k's from a tank in my 95 2.0v6 Vitara around town and I don't drive it with economy in mind. the tank holds about 60l. the thing does drink the gas off road in low range
- PuddleJumper
I get 450Ks - 500Ks on my road tyres (215/75R15 on alloys) and around 250 - 300Ks on my 30x9.5R15 mud tyres on steel rims. Mine is a '93 1600cc 16Valve. Dont forget if you have lots of heavy accesories attached then this will hurt consumption as well!
its almost worth me changing tyres just for road use with so much difference in fuel economy, id like to see what other people are also getting with 30 or 31s
- PuddleJumper
Thats exactly what i do. Just put my mud tyres on when i need them. That way the mud tyres last for ages too!
my 31" muddies are my only tyres at the min, my truck looked stupid with 195/15's on after it got lifted:lol:
ive noticed the fuel consumption has gone up a bit, but i still get about 400k to a tank full. mines a 5 door and ive got bars etc on it too.
weemsy
weemsy
The early 3-doors only have a 36 litre tank, so don't expect great range. (And once they've been offroad they usually shrink to about 30 litres after the bottom of the tank is well and truly stoved in.)
With 31's on an 8-valve EFi manual, I get about 250-300kms, The big rubber sucks a LOT more fuel with the little motor.
Of course, if I was overly concerned with fuel economy I would not drive a 4WD with big rubber. As far as I'm concerned I'd rather spend a little more on gas than faff around with swapping tyres every weekend.
put a new air filter in it coz that can suk gas if its choka bloc
my 94 1.6 inj 16v 3dr is shocking on fuel is only used off road and short drives from home to the bush or river 8k max , off road it is no worse on fuel than my v6 paj which is pretty bad.
vaughan
vaughan
- joeninetynz
- Driver/Navigator
My is a 94 1.6inj 16 3dr too. It has a 36litre tank and I'm getting 350k's out of her on city drives. Has anyone do a tank swap to a bigger capacity?
Dirty Bugger!
lneil wrote:The early 3-doors only have a 36 litre tank, so don't expect great range. (And once they've been offroad they usually shrink to about 30 litres after the bottom of the tank is well and truly stoved in.)
Yea I can attest to that too. Took just two trips to get it on a nice angle. But even before then I too was only getting at the most 200km per tank. even when i drove it nice it still didn't help, but bear in mind I have the 8V, single carb 1600 motor in it. every thing else is standard.
Lincoln
