pajero wont start
lil_tank
pajero wont start
Post by lil_tank »
hey all just throught id pick ure brains just brought a 92 pajero 2.5td
when i brought it was told the golw plugs need doing all good did those ans relised the timer was shot as well so at the moment have that on a switch put it still wont start it turns ova fine but wont egnite
the werid thing is that it can be tow started ans runs fine it just wont go under it own pwr stupid thing :oops:
just wondering it any one come across this problem before or sum more ideas on what could be
tgaguy1
Re: pajero wont start
Post by tgaguy1 »
Do a compression test. You will find it is probably low. 4d56 blocks had very soft bores.
kaney
Post by kaney »
tgaguy1 wrote:Do a compression test. You will find it is probably low. 4d56 blocks had very soft bores.
in other words u got a lemon
toymota thats stock standard.
lil_tank
Post by lil_tank »
it does happen sum times
pajeroboy
Post by pajeroboy »
thats what me and jono think to,low compressonin one cylinder.only other thing could be air sumwhere it shouldnt b but where is the prob.
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
pajeroboy
Post by pajeroboy »
well we had a nosey at this today,found that the glows were shot(the new ones terry got) changed them over still no luck.has got lots of fuel getting to injectors,has air fuel and glow,starter motor working fine,so still leading to compression.
does anyone know of where we could borrow a diesel compression tester from.
starting to feel bit bad for my mate terry a,wanna get his POS up and running again.
SAM
red-devil
Post by red-devil »
ill see if i can get a hold of one. but it wont be untill after the 5 jan. let me know
mud_slinger
Post by mud_slinger »
show us your lemon :wink:
needs more curry
0272593533
pajeroboy
Post by pajeroboy »
yeah that would be good,will let you know if still needed after then,it not going anywhere with out a tow start
SAM
yorick
Post by yorick »
lil_tank wrote:hey all just throught id pick ure brains just brought a 92 pajero 2.5td
Did you check if you're getting power to the Glowplugs. the Glow plug relays could be dead. Chuck a jumper lead from the front battery to the link between the plugs, give it a few seconds and try starting it. Don't leave it there for too long, 15 secs tops.
Return to “Mitsubishi”
