3rzfe boost able?
cool__bananas
3rzfe boost able?
Post by cool__bananas »
is a 3rz out of a 97 surf anygood for a small turbo or supercharger? or will it blow to bits?
any knowledge is appreciated, cheers
haynzy
Re: 3rzfe boost able?
Post by haynzy »
cool__bananas wrote:is a 3rz out of a 97 surf anygood for a small turbo or supercharger? or will it blow to bits?
pm jafa pretty sure he has looked into and the result is bout 300hp :twisted:
Bulletproof
Post by Bulletproof »
You are talking about useless figures for 4 wheeling .Torque at low revs is what counts.
cheers Richard
Never say die, up man and try
turoa
Pyro Junior
Post by turoa »
cheers Richard
I disagree. its not only about torque but thats not what the threads about. Its for his road car
cool__bananas
its for my road car which i may occasoinally use for towing
Jafa
Post by Jafa »
they turbo really nicely, get up to 1500hp in the US on these. so anything is possible, just how much cash :lol:
I should imagine a lazy 300 would be very easy to get, prolly 10 psi and reliable as hell
Have a look here to see whats possible
http://www.lcengineering.com/index.php
021 273 9942
jafa@inspire.net.nz
vvega
Post by vvega »
cheers Richard
if you put the right sized turbo on it for what yoru wanting to do you can not only increase peak t but also bring it down the rev range :D
300 hp @ 2000 rpm give you a whopping 787 Pound Foot
300 hp @ 1000 rpm 1575 Pount Foot
though to get those sorts of figgures id be going for a blower with about 50 psi :D
Kiwi4x4
darinz
Post by darinz »
vvega wrote:
cheers Richard
That is why we turboed my motor.
Out of the factory peak torque was at 4000rpm (400nm) but it has 320nm (80% at 2000rpm. Our goal was to get peak torque but 3000 rpm without sacrificing any top end.
I've got a way oversized turbo (but it is a dual ball bearing turbo) and I have boost at 2000rpm with full boost (and peak torque) at 3000rpm.
The other advantage is a wee bit more top end as well!!!!!!
The other coment I have, is low end engine torque is all that is important then every Suzuki out there would be a complete POS off road!
