leaking gearbox
leaking gearbox
the filler bung on my transfer box is leaking and after a trip to queenstown have decided that i want to sort it as there was oil splattered on the rear diff (it leaks more when hot) and i dont know what is going on because me and a mate took filler bung off and about 1 litre of oil came out then we put bung back on so it was full then checked gearbox and that is full but pto is empty,also ahd a machanic mate do a few jobs on it and he sorted the bungs but it still leaks around the bung area so it dosent look like the bung is the leaker
Death to the competition
Re: leaking gearbox
look for a leak above the bung (gasket, seal etc) that the oil is flowing down from.
Re: leaking gearbox
yea a mate said he had a seal go in there on his cruiser,should i wory or just keep an eye on the main gearbox oil as thats where it running down from and just top that up when needed
Re: leaking gearbox
if oil can get out, water can get in. You need to fix it properly otherwise you'll just end up with more issues.
