After a complete speedo cluster for a GQ safari,1990 model,has yellow numbers on face not white like the later ones.anything from 1988-1991 should be correct.
Cheers Shane
021338855
GQ Speedo Cluster WTD
Re: GQ Speedo Cluster WTD
i will have a hunt for you shane had 2 of them one for spares and 1 complete,last time you was round mine in christchurch i had one on the bench you remember??,mind you have not seen it since i moved but will look for yer
vince
vince
PigFmr wrote:i will have a hunt for you shane had 2 of them one for spares and 1 complete,last time you was round mine in christchurch i had one on the bench you remember??,mind you have not seen it since i moved but will look for yer
vince
I,ve got that one its the wrong year,white face dials
Do you want the high tide mark through the gauge, or will you put it there yourself.
KEEP OUT OF THE SELWYN,
FITZY.
FITZY.
SMOKEY wrote:Do you want the high tide mark through the gauge, or will you put it there yourself.
FITZY.
FITZY.
There always one.....theres no tide line on the one I have,that was up higher
