solid axle passenger steering arm
new2zukes
Post by new2zukes »
well im after the passenger side steering arm off a solid axle hilux axle mine is 4.8 ratio if that matters.
Re: solid axle passenger steering arm
is your's bent?, if it is PM JAFA who can make you a new strong one cheap
new2zukes
Post by new2zukes »
na trying to get histeer without spending 400 odd on jafas hi steer arms
wopass
Post by wopass »
i had flip arm set up and then bought jafas high steer arms as they are WAY better and the 400 is well spent.with all the pissing round to get the flip arm set up working properly and strong enough to take the abuse you might as well just spend the coin to start with and they just bolt on. so simple and so strong its worth it.
niblik
Post by niblik »
wopass wrote:i had flip arm set up and then bought jafas high steer arms as they are WAY better and the 400 is well spent.with all the pissing round to get the flip arm set up working properly and strong enough to take the abuse you might as well just spend the coin to start with and they just bolt on. so simple and so strong its worth it.
ditto
wopass
Post by wopass »
ohh but if you still want to go down the flip arm track i have a flip arm set up you could buy for 180 buks :wink:
yes im short on cash and selling stuff to fund other parts :lol:
new2zukes
Post by new2zukes »
hey thanks for the reply wopass my plan was to do the following
then i will gusset this to make it stronger then just get longer bolts i dont see a problem with this but as you have gone down this path before what sort of effects does it make to the steering, il be using a ifs power steering kit.
martin
wopass
Post by wopass »
im at work at the moment and cant see the pics but will have a look when i get home at about 12:30...thats an hour away!!!, YAY!!!....
IcedJohnno
Trailer Trash
Post by IcedJohnno »
EEERRRR Steering components that are known to be reasonably highly stressed and then you weld them?
I think not, plus of course for a certed vehicle welded steering components are a no no. Not that I always agree with that but I do in this instance. If you look at the sample in the piccy the right hand end of the weld in-between the two arms has undercut. NICE!! Not only does the steel have a heat affected zone from the welding but it has a undercut stress-raiser as well.
Go buy WOPASSes ones, Its you life AND others you are playing with.
wopass
Post by wopass »
yea no welding on steering components !! big no no.
just flip it,double cone washer set and bolt them on easy as. or you could just buy some high steer arms and bolt them on with your existing studs and cones and nuts. they are better. but if you want the flip arm set up i can dig around and sell you mine, you will have to get studs tho as im pretty sure i biffed mine out when i bought the high steer arms :roll:
new2zukes
Post by new2zukes »
thanks for all the info i am not a gd welder anyways so i wont be welding an arm up. think i might have to fork out for the arms although i do not intend to get this truck anywhere near road legal but its nice to have that piece of mind that it will be strong enough and not break.
thanks again
martin
wopass
Post by wopass »
new2zukes wrote:thanks for all the info i am not a gd welder anyways so i wont be welding an arm up. think i might have to fork out for the arms although i do not intend to get this truck anywhere near road legal but its nice to have that piece of mind that it will be strong enough and not break.
thanks again
martin
good on ya mate, get the high steer arms, its the best option in the long run :wink:
vvega
Post by vvega »
to get welded arms certed you need to aplly for a exemption before you do it stateing why there is no alternative and then the method your going to use to weld them
its quite a complicated procedure ,,, but there is a reason for it
good to see yoru gunna get some arms ... its a good investment
Kiwi4x4
