wheel size for navara
For all Nissan related topics
rockyman
Post by rockyman »
hey just wondering what the biggest size of wheel i could put on my navara? i was going to put 15x8 rims and 33x10.5 tires on. will it work? will i have to lift it?
albundy
Rolly Polly
Re: wheel size for navara
Post by albundy »
Navaras and terranos are the same in the front. You will have to lift it. Also you will need to check the offset on the rims to ensure they don't rub on hard turns. Perfect sized tyre though. I ran this size on my terrano and had more clearance under the diff then a saf or cruizer on 35's. You may need to reinforce the idler arm though as it will be under considerable pressure.
Al
