Diff Ratio
brakes-shocks-lockers-etc
hellzuki
Diff Ratio
Post by hellzuki »
Hey all, just looking for some hilux diffs and not sure what ratio is the best to go with. running 35's. whats better? 4.5, 4.8 or 5.29?
And how do you find out what ratio your diffs are?
madaz068
Re: Diff Ratio
Post by madaz068 »
pm nomis on here he sells diffs
hellzuki
Re: Diff Ratio
Post by hellzuki »
i found some cheap diffs, hilux 4.5 front and rear. would they be any good?
Smurf
Re: Diff Ratio
Post by Smurf »
What vehicle? what motor? A bit of information would make it easier for guys to make suggestions.
I have 4.88 diffs in my surf with a 2.8 straight six motor running 35's. I think it is still too high in the gearing
Re: Diff Ratio
Smurf wrote:What vehicle? what motor? A bit of information would make it easier for guys to make suggestions.
wot he said
we need a little more info on wots powering it etc etc etc
as a side note, most of the trials guys run 4.8s, there are a few who run up to 5.7s and a couple in between who go down to 3.7s.
its dependent on a whole bunch of other stuff dude
and so on and so on
help us out with a little more info and watch the comments fly
allright, I posted and went away and found this.........
viewtopic.php?f=23&t=14716
so I would say that you may wanna try and get 4.8s, they are harder to find, but would probably be better gearing for what you are going to do, which is similar to what a lot of trials guys are running. PM MrO to see what ratio he got, as hes running 36s I think.
SKID
