Wasn't sure where to post this.
Is the guy posting these a member here?
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Steering/auction-201966769.htm
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Nissan/Accessories/auction-201966437.htm
Just got a mate interested in the patrol gear.
Trademe Auction Guy
Re: Trademe Auction Guy
Steve from ChCh, not sure if he is a member, but he has a couple of mates on here. I run his lower arms, sold the drop boxes to a member in welly, so not sure how those go, but no problems with the arms so far.
DaveM wrote: sold the drop boxes to a member in welly, so not sure how those go, but no problems with the arms so far.
Think there the ones Curly brought, they need some minor modifying to fit his truck?
Sadam_Husain wrote:DaveM wrote: sold the drop boxes to a member in welly, so not sure how those go, but no problems with the arms so far.
Think there the ones Curly brought, they need some minor modifying to fit his truck?![]()
Thought they were meant to bolt straight on without the need to mod
Swamped wrote:Wasn't sure where to post this.
Stephen Ransby s.ransby@xtra.co.nz
- curly12
DaveM wrote:Sadam_Husain wrote:DaveM wrote: sold the drop boxes to a member in welly, so not sure how those go, but no problems with the arms so far.
The holes did not match-up with the crossmember bolts holes. Needed to drill them out by a few mm to fit
Bugger, I never tried fitting them as I thought I was going to run drop arms, but then ended having to buy another set
hey steve here
the hole prob has been fixed on the boxes long ago...
iam no longer moding old rear arms, but now making arms from scratch..
also trying to get some ome bushes for front and rear arms into nz..
megaflex front arms are almost ready should have one finished next week (a bit like your arn dave)
ready for testing in reefton at easter...
steve @ advantage 4wd
s.ransby@xtra.co.nz
s.ransby@xtra.co.nz
Some pics of how they perform at some point could be cool.
If they get more flex on the patrols I could be keen
should give +200mm of travel or max out your front shocks wot ever comes first...
will post pics off ramp testing as soon as i can...
- Driver/Navigator
stainless wrote:should give +200mm of travel or max out your front shocks wot ever comes first...
how did you work that out?? copied off superior engineering??
no it's not at all a copy. sorry to make it sound that way but in no way is it a copy..
