good brake pads for landcruiser
xorph
Post by xorph »
Its cert time for my 70 series and I need my brakes to be in top shape to pass the 100-0kph in 4 secs brake test requirement.
Its got newish 'Silverline' brand pads from repco on front but they are terrible, Im convinced the std toyota pads work much better.
What is a good brand of pads that will help it stop better and also last the distance? Im prepared to spend a couple hundred to get quality this time.
Matt
DaveM
Re: good brake pads for landcruiser
Post by DaveM »
I always use Bendix pads for my 4wd's, find they pull the hippo up quite well, although the compound I use work a lot better with a little heat in them
hilux_dave
Post by hilux_dave »
http://www.znoelli.co.nz/Brake_Pads.htm
i use these stop 36s for curt no prob
xorph
Post by xorph »
Ill investigate those 2 brands.
Is it a good idea to degrease and sandpaper the discs?
wopass
Post by wopass »
i just use decent frodo's from ripco, the work ok and still cheap :wink:
gimmemud
Post by gimmemud »
I second the ferodo pads, They stop my truck awesome! And about half the price of bendix. Got a set of bendix here for my surf which i got given, which i'll try out next time.
GotFlex
Post by GotFlex »
Genuine they are cheap :lol:
SMOKEY
Post by SMOKEY »
Bendix make a 4WD front pad, they are the only ones that stop my 70# in all conditions, they are a soft pad and with mud and crap in them you don't get many K's out of them, about $80 a set.
FITZY.
xorph
Post by xorph »
thought I should update for others' benefit,
ended up going with Ferodo Excell pads as they were the best I could get in a short time.
I can highly reccomend them to Cruiser owners, can now lock up the wheels in dry. cost about $70 I think
kruza wazza
Post by kruza wazza »
always used bendix, towed alot of big shit for a long time, value and do the job.
