Leaking diff (70 landcruiser)
alright boys
My diff is leaking from where the drive shaft enters the diff.
Whats the problem i have, is it major or what
Its been doing it for a while now but as its toyota has just kept on going
- skid
- Tyre Man
Re: Leaking diff (70 landcruiser)
pinion seal
but I may be wrong
and someone will come along and correct me soon
but I may be wrong
pinion seal. 14 dollars for a new seal and 10 min work
get new seal
remove rear prop shaft (two 14mm spanners)
remove pinion flange nut (30?mm socket and power bar)
pull pinion flange out carefully.
remove seal
fit new seal
slot pinion flange back in carefully
tighten pinion flange nut back up to where it came from (tab indent)
re-fit prop shaft
top up diff oil
job done
easy eh
get new seal
remove seal
fit new seal
re-fit prop shaft
top up diff oil
job done
easy eh
- Andrew1706
Sweet as, I need to do this with my 60 series rear diff.
What about replacing the pinion bearing, does the whole head need to be removed?
- MNC
minimun wrote:alright boys
If you don't have the 10 mins for the procedure Wopass has suggested you could just park it on a step bank so the oil sits at the front of the diff head away from the flange.
wopass wrote:pinion seal. 14 dollars for a new seal and 10 min work
get new seal
remove seal
fit new seal
re-fit prop shaft
top up diff oil
job done
easy eh
seems maybe like something i could do myself then
MNC wrote:minimun wrote:alright boys
that would work also
minimun wrote:wopass wrote:pinion seal. 14 dollars for a new seal and 10 min work
get new seal
remove seal
fit new seal
re-fit prop shaft
top up diff oil
job done
easy eh
yes you could, or get a workshop to do it, they would charge a min hour at a gi=uess so the job would cost you (guessing a mark up on the seal) 80 bucks?
Andrew1706 wrote:Sweet as, I need to do this with my 60 series rear diff.
pinon bearing yes diff head out and you need to have a lot more experience to do that as you have to re set all the lash etc etc
- Andrew1706
wopass wrote:pinon bearing yes diff head out and you need to have a lot more experience to do that as you have to re set all the lash etc etc
Yeah I know that, it's a factory 60 series cable locker so I can't use the 'oh well while it's out I'll get a locker put in it'
You can replace the seal with most tools in a basic kit, the only troublesome thing would be taking out the dent thingo that holds the nuts on the pinion shaft, you need a punch for that.
Gear puller is also handy and I just bought one incase you cant get it off you can borrow it ..
My method is easier, when it stops leaking it time to refill. That way you always have fresh fluid in there
The problem comes when the diff head fills with crap and water, grinds to a halt and costs of $$$ to fix
Benjamin Franklin
Benjamin Franklin
yea i think i might have a bit of the h2o in there now so shes retired from daily til its fixed
the wonders of have a second car
Bubba, I thought your method was to strip everything completley and then get confused and then take it to a mechanic
rang bnt and they dont stock them
Who else might i be able to get one off?
ripco stock them or can if they dont have em in stock
rang around repco but the only places that had them were out west and so on
bit the bullet and rang Giltrap City Toyota as a long shot
14 bucks and i got my seal
minimun wrote:rang around repco but the only places that had them were out west and so on
bit the bullet and rang Giltrap City Toyota as a long shit
rad !!
go toyota!!
I have an 80 series and have just done this to the front diff, but have found that the rear drive shaft is leaking from the transfer case... Is this as easy to fix?
- MNC
wopass wrote:ripco stock them or can if they dont have em in stock
Went to Ripco today to buy a oil seal - their shipment was due mid March and still hasn't arrived
Might try Auckland Bearings during the week.
I did have 2 good ones but watched them drive away today
