Hey just wondering if any body has done a body lift on a terrano as i'm going to do mine shortly and are keen to hnow if there is any majors envolved ?
Any info appriciated, i have looked at the all the american sites but no body has really giving me any hard facts ie if brake lines end up to short or anything like that.
I have done my 94 V6 2" body lift. Five mounting points down each side. Go side to side as the floors are two piece and if you go front to rear as I did you will split the weld and end up with a leaking floor, now gupped.
The steering is on a spline so slides easy enough to adjustment. The radiator will need remounting as the fan will be to off centre. The power steering lines needed extending but nothing else. If you go over 2" then you will need major modifications ie: cutting floorpan to allow for changing gears, extending gear shift lever, and no doubt extending of brake lines.
happy lifting.
Al
