am sick of not startin when i need it. have huggers that hug the block that fkin much i cant get my starter off without removing rhs pipe set up.
have seen reman starters in petrol head for 129. should i stay away or go better.
where would i get one in "the hutt" or wgtn? ( jerry?)road an trac?
warwick
new starter fof my chev/fj
Re: new starter fof my chev/fj
call Sylvester performance 0800 327 350 get a brand new high tourqe for $180ish
- kruza wazza
cool where s he in the country?
sylvester is in chch i think, or go for a tilton starter, hi torque geared reduction starter. not cheap but reliable. also do you run a relay on the starter solenoid?
- kruza wazza
nah no relay there , std 74 fj wiring.
should i have relay?
when it wont crank the amp guage is going way down. and then you clear where you are and it goes!!
yea they in chch, depending on what year it is and what size flywheel/ringear it has you may or may not be able to use a tilton.
they do C.C over the phone and delivery is fast, good guys good service. mostly good prices to.
exept for thier price on a new Holley truck avenger carb
- skid
- Tyre Man
wot they all said
dont piss around
get a high torque starter
its a must
dont piss around
its a must
- kruza wazza
would you get one in wgtn on a sat morninin or not?
- skid
- Tyre Man
kruza wazza wrote:would you get one in wgtn on a sat morninin or not?
you could try...............
American V8 Performance at the bottom of the normandale hill
Road n Track
some place in Upper Hutt in montgomery cres
or you could even try Magoos over your way
with any luck someone else with come up with other suggestions
good luck dude
