70 series MWB / 70 series Prado
fweddy
Post by fweddy »
How compatible are these between each other?
Basically what I'm thinking is what mods would be able to be swapped over to a prado from a midi?
I understand the running gear is all different — diffs, suspension etc but what about the likes of front and rear chassis (bar fitting, etc). I figure PTO is a no go as different transfer case. So its not leaving much of the good stuff that is interchangeable.
mickey
Re: 70 series MWB / 70 series Prado
Post by mickey »
doesn't the older prado's have the same split transfer case as cruisers?
mudmike
Post by mudmike »
My prado has a big pin 70 transfer case, have put a pto winch on it. Had to split it to put the drive gear in. I think the bullbar will fit. I went all custom with mine.
Diffs are 8" so can't swap, but the hubs and stub axles will and is a good mod to get shot of the crap electric free wheeling hubs.
With Toyota alot will swap.
Good luck
