What`s a better option.intercooler or boost compensator?
3rnzir
Post by 3rnzir »
For a retro turbo upgrage.
mumad
Post by mumad »
Both, i certainly have on my mu, intercooler with a fan on top of it, and a in-cabin boost controller which lets me wind it out to 16psi 8)
3rnzir
Post by 3rnzir »
Hi mumud,the reason I asked this Q was I recently read a reveiw in the Aus4x4 mag.The dude did the turbo upgrade but wanted no increase in full consumption.Anyways,turns out,that he went the boost compensator route only.The BC was tweaked to give him another 11% power increase over the turbo only option.Smoke emissions at start up/low revs almost disappeared.And got a slight improvement in fuel economy.The boys at the workshop couuld have given him more power.But get this.The BC cost around $1400 and a intercooler option can cost anything upto and over $3000.Around half the price for similar improvement,without additional engine room clutter.Still you can`t always belive what you read.
Cheerz
mumad
Post by mumad »
:shock: :shock: Sounds like this person got ripped off!! was the boost controller gold plated or something!!
I did my hole boost set-up, guage and everything for under $100, the intercooler which came off a bighorn, so was a pretty much bolt on was under $300, start to stop, not including time though, but even an incabin boy racer boost controller is only like $300-400??????
3rnzir
Post by 3rnzir »
Wonder if that was an Aussie standard charge.Or a bench flow test on the fuel pump may have been included in that price,maybe?
mumad
Post by mumad »
I would think so, that would make it at least reasonable, its quite a simple operation to do, easy if you know what you are doing!!
Heath
Post by Heath »
mumad wrote::shock: :shock: Sounds like this person got ripped off!! was the boost controller gold plated or something!!
Boost compensator not controller.
mumad
Post by mumad »
:oops: my bad whats the difference then???
Heath
Post by Heath »
Not 100% sure of terminology but here goes.
a boost controller varies the amount of boost (PSI) before the waste gate opens.
A boost compensator varies the amount of fuel the pump puts out based on the amount of boost (PSI) pressure.
I could also be talking through a hole in my A%% but thats how I think it works.
A more tech savvy person will confirm my intelegence / ignorance no doubt.
Heath
mumad
Post by mumad »
Oh i see, so i am well out left feild and full of crap!!! :oops:
Sorry bout that, i should read more carefully aye!!!!
3rnzir
Post by 3rnzir »
So Heath,does that $1400 price tag for the BC sound about right then?
Heath
Post by Heath »
Sorry, no idea I just read the article as well and dont really know what the dohicky does or how it does it other than the basics. But if I were to guess (horsepower aint cheap) and if it is a slow moving item then I would expect it to be expensive.
Best ring a diesel turbo specialist and bend their ear for the real word.
Heath
Return to “Tool Shed”
