Hi
I've got a kzj78 prado a '93, with the 1kz motor, have a problem with the exhaust exit into the driver side guard then down the side. Has anyone done a fix to tuck it out of the way? even a pain to build side bars around.
If anyone has a fix they have done am keen to hear and pics would be great.
Thanks
Prado 70 exhaust fix
Re: Prado 70 exhaust fix
hey dude, im goin thrugh an exhaust build now and was thinking about how to do that. i dont really want to smash in the bulkhead there. so im keen for that answer too, as im building a new dump pipe there i may be able to change the angle of the exit point a bit but its tight in there huh.
Mine and a mates goes down the inside, above the trans, but it'll cost $$$'s
Who knew Prados could fly?
any chance of a pic or two before i build my dump pipe??
wjw wrote:Mine and a mates goes down the inside, above the trans, but it'll cost $$$'s
Thanks for the reply, how close to the floor and brake lines have you gone?
will look at this option to see if I can run it there to, A pic or two would be great if you had the time to get them up.
Thanks
chop out the fire wall a bit? move the lines over and run strait down, or hammer it in
When it stops raining I'll take some photos...
