brake booster vacum/oil pump
my alternator crapped out so as i was replacing it with a new one i noticed that the oil pump which is bolted to the alternator has a rubber vacuum pipe from the brake booster to the oil pump and it had collapsed on itself and i'm guessing wasnt working as it was flat as, ive fixed it but what does this vacuum pipe do with the oil pump ?
Re: brake booster vacum/oil pump
think you'll find it's a vacuum pump for the brake booster on the alternator not a oil pump. it's just lubed with oil from the engine
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
Yes, just what rugger said.
What truck is this out of?
Ph 0212078472
Ph 0212078472
ok cool thanks! l200 with 4d56-t
yeah noticed my brakes are far better at speed now ones the vacuum builds up so that good!
