vzn130 surf v6 3l milky under oil cap
just took the old surf for a run today and after i took it for a run hadnt been used for so long came back and under the oil cap was milky so i cleaned the cap off took it for another run and got back checked it again and nothing ? dip stick oil was sweet no milkyness, radiator has no oil streaks in it so could it be possiable from just sitting round so long ? i know those engines are bad for doing heads but its the last thing i wanna do as my escudos just cracked its block
not having much luck! oh surfs also not b lowing white smoke even at the rev limiter was nothing!
Re: vzn130 surf v6 3l milky under oil cap
after the sons 40 sat of a long till milky under oil cap cleaned it up no more deposited so just moister in the air
Probably just condensation from sitting for so long if it's not losing coolant.
