http://www.med.govt.nz/templates/Page____10373.aspx
Should I still be looking at buying an older diesel surf??
Diesel - difference in fuel
From what I'm told, if the seals are relatively new in the pump you will be fine, if not, use a fuel additive (moreys is supposedly good) to slow/stop the seal leak problem.
Otherwise, take the risk, and try to budget for a pump rebuild, which may be on the cards anyay for an older diesel motor.
Dave
Dave
