rancho 9000's
rancho 9000's
hey all just rebuilding my truck have the cab off with new cab going on, painted the chassie and noticed that 2 of my rancho's are buggered, i have the 9 stage adjustable in cab controller hooked up in the cab.
so question is does anyone know where is the cheapest place to get some new shocks moses well replace the lot im thinkin.
Re: rancho 9000's
vvilly wrote:so question is does anyone know where is the cheapest place to get some new shocks moses well replace the lot im thinkin.
Cheap is just that, you get what you pay for. Might be worth researching what sort of shocks would suit your truck and your budget and then look for pricing
- skid
- Tyre Man
Re: rancho 9000's
its worth noting that the winch challenge guys dont run ranchos
and theres a very good reason why
ask wopass how long his lasted at the rotorua winch comp
Re: rancho 9000's
skid wrote:its worth noting that the winch challenge guys dont run ranchos
i am currently using them and have the adjustable controller/compressor inside the cab and have no issues with them but two of them are dented
whats wrong with them?
Re: rancho 9000's
the welding on the eyes is poor and they snap off
inconsistant induction hardening on the spears making them brittle at points
and the valving falls apart
other than that there fine
... though p&h in hams dont like selling them to anyone that actually goes off road .. to many warrentee's
plently of choice out there mate
Kiwi4x4
Re: rancho 9000's
vvega wrote:the welding on the eyes is poor and they snap off
other than that there fine... though p&h in hams dont like selling them to anyone that actually goes off road .. to many warrentee's
ok then since i already have the adjustable control in the cab is there any other shocks thst will mount up to that
- rangimotors
Re: rancho 9000's
vvilly wrote:skid wrote:its worth noting that the winch challenge guys dont run ranchos
what has happened to dent the current two? no point going out and buying the best shocks on the market if something is hitting them when the truck flexs up or something.
Re: rancho 9000's
rangimotors wrote:vvilly wrote:skid wrote:its worth noting that the winch challenge guys dont run ranchos
one of them is dented nothing from the truck has impeeded this damage i think it may have been a rock or tree etc they are pretty well secured in there and out of the way
so if i replace one of them moses well replace pair
Re: rancho 9000's
vvilly wrote:ok then since i already have the adjustable control in the cab is there any other shocks thst will mount up to that
Do you actually need to be able to adjust the shock dampening rates or is that just a bit of bling factor with the in cab controls?
Re: rancho 9000's
Sadam_Husain wrote:vvilly wrote:ok then since i already have the adjustable control in the cab is there any other shocks thst will mount up to that
What sort of daft question is that of course he needs the bling just like you need those buttons with the blue lights
Re: rancho 9000's
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=17&t=15555&p=177007#p177007
thats what i brought and re building
Re: rancho 9000's
I've had two sets of rancho's in the front of my truck now and its not just offroad that kills them, they last for about 3000km's on road then piss all the oil out
Who knew Prados could fly?
Re: rancho 9000's
wjw wrote:I've had two sets of rancho's in the front of my truck now and its not just offroad that kills them, they last for about 3000km's on road then piss all the oil out
i had them in my terrano, got them in the arse end of mrs truck and also in the big girl and not had any issues
- MNC
Re: rancho 9000's
Tough Dog make shocks that work with the rancho in cab kit. Used to have that set up in my old 40. Didn't have it long enough to test them hard out off road
Re: rancho 9000's
MNC wrote:vvilly wrote:ok then since i already have the adjustable control in the cab is there any other shocks thst will mount up to that
Tough Dog make shocks that work with the rancho in cab kit. Used to have that set up in my old 40. Didn't have it long enough to test them hard out off road... maybe the guys on here have an opinion on them...
any other thoughts on these tough dog adjustable shocks
will start googleing myself
Re: rancho 9000's
vvilly wrote:MNC wrote:vvilly wrote:ok then since i already have the adjustable control in the cab is there any other shocks thst will mount up to that
wellfirst post i came to and bam i think tough dogs have got a worse rep than rancho's
http://www.exploroz.com/Forum/Topic/12843/Toughdog_suspension_-_not_happy_expensive__I_thought_they_would_last.aspx
so any other options
Re: rancho 9000's
Forget about the in cab adjusts as it is just bling. Get a set of well matched shocks and springs and you don't need adjustable shocks. The adjustablility is only needed to match to the springs so once set, basically forget.
Lets put it this way, if there was need for on the fly adjustable shocks then those of us that are spending serious money on suspension would ALL have adjustable shocks. My new ones are infinitely adjustable but they need to be pulled apart to do it. The difference is they are a long travel coil over with remote canister so one costs the same as all four Rancho's but after a few years they will be cheaper as they will still be going strong just by fitting a set of shims (valving).
Re: rancho 9000's
How does one tell the numbers on the side of a Rancho shock?.
I have these numbers, 9223 and c145u2r.
Re: rancho 9000's
9223 should be the model number, these appear to be RS 9000, used on the front of 91-00 Pajero's
Re: rancho 9000's
Nice, cheers muchly.
