a gear box question
HBpajero
a gear box question
Post by HBpajero »
I have a 93 GNXE v6 Pajero with a 5 sp manual box. Since i bought it there is a stiffness when putting it into third gear. If you take your time it slips in smoothly , if you try to hurry the change it "sticks" as it goes in and you have to give it an extra 'push'. I've tried double clutching but doesn't make any difference. This happens going up and down the gears. Has anyone any ideas. My thoughts leaned towards a worn syncro in third maybe. Open to ideas.
nicinnz
Re: a gear box question
Post by nicinnz »
Yes third gear syncro will be a bit tired. Try changing the gearbox oil, use VMX, also add some Pro ma MBL8, it works wonders with syncro's that are a bit tired.
NH SWB Pajero 3.0L V6 manual Rear locker, lifted, Snorkel KL71's Warn winch Various dents and scrapes
NT LWB Pajero Exceed 3.2 Diesel Factory rear locker
motorhead
Canadian
Post by motorhead »
I have the same problem with my 90, where can I buy this oil?
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
NJV6
Post by NJV6 »
VMX is from Castrol and can be found almost anywhere. The MBL8 i found at Mitsubishi dealer.
motorhead
Canadian
Post by motorhead »
Thanks for the info.
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
HBpajero
Post by HBpajero »
I posted same question on the English Pajero site.http://www.pocuk.com/forums/index.php?s ... 5c52f97839 They suggested replacing gearbox oil with ATF oil. With the same result.
flyingbrick
Post by flyingbrick »
I suggest using Redline MT90. Its absolute MAGIC for worn manual boxes.
Return to “Mitsubishi”
