Hi guys, as per title really,
ive just bought a surf with a 1jz-gte in it (twin turbo 2.5l soarer engine) but its auto running the surf auto box. Im going to do a manual conversion, looking at running a r150f surf box (out of v6 surf) so need to adapt it
will also need r150f gearbox, clutch pedal box, clutch master and slave cylinder
Cheers for any help in advance
Dan
1jz-gte to r150f bellhousing or adapter wanted
Re: 1jz-gte in a surf, bellhousing needed
bump
- muddyhilux
Re: 1jz-gte to r150f bellhousing or adapter wanted
mhm must have missed this thread,what model surf 130 series?if so i can do pedal box,and should have a clutchmaster,may even have a slave,and just up the road in auckland,what they worth to ya?
Sweet, yeh ln130. PM sent
hi mike,im currently doing a 1jzgte conversion into a 1989 ifs surf and i was wondering befor i start ( i have the truck and 1j )spending some money if i could grab some measurements off yours please?
hey mate,
I have since sold my surf. but ended up using the chaser auto bellhousing with an adapter plate to the box. I put a spigot bearing in the back of the crank so the input shaft ran in there. I can't remember the thickness of the adapter plate but it was like 12mm to get the input shaft sitting in the right place as the bellhousing was quite shallow. I used a hydraulic release bearing off a v6 vectra and piped it in. Clutch was a 6 puk push type supra clutch
Cheers, DAN
Cheers, DAN
