diff ratios
brakes-shocks-lockers-etc
new2zukes
diff ratios
Post by new2zukes »
hi well i picked up a surf diff today to put in my suzuki and decided to check the ratios, i counted 2.5 turns of the d shaft to 1 turn of the wheel. the diff is lsd if this means anything so would this make the ratio 2.5:1 if so it sort of doesnt make sence as i thought surfs were like 4.3 ratios. hope someone can help.thanks
martin
chevrolux
Re: diff ratios
Post by chevrolux »
rip it out and count the teeth. i think there is a colour system as well for the pinion nuts. but not 100% on that. mine are 4.55 and have yellow on them. i think that 4.3 is blue but like i say not 100%
gimmemud
Re: diff ratios
Post by gimmemud »
and most of them just say the ratio on the crownwheel
Rotazuk
Re: diff ratios
Post by Rotazuk »
One wheel or two . One wheel and the diff is working , ie the spider gears are turning doubling the turns on the wheel . So you need to double the figure you get , ie 2.5 will be 5 etc . That is most likely a 4.88 , think that is a common size in surfs . Have to be acurate when counting the turns that way as a small error is multipled .
Chris
nstacey
Re: diff ratios
Post by nstacey »
Rotazuk wrote:One wheel or two . One wheel and the diff is working , ie the spider gears are turning doubling the turns on the wheel . So you need to double the figure you get , ie 2.5 will be 5 etc . That is most likely a 4.88 , think that is a common size in surfs . Have to be acurate when counting the turns that way as a small error is multipled .
Chris
I think most petrol surfs/hiluxs are 4.88
85 Hilux single cab
02 Grand Vitara
new2zukes
Re: diff ratios
Post by new2zukes »
hi this was a 2.4 turbo diesel, will pull it out when i need to mount the diff but i need the ratio to be 4.88 as the front diff is this, but if this diff is not that i can just put the head from the one thats in the truck to the one im putting in. if that makes any sence.
also as it is lsd i was wondering if the lsd bit will fit into a 1985 hilux front end the diff ratio for it is 4.88. thanks for info guys its much apreciated.
