Anyone know the location of this on the engine, and if its accessable from the outside without taking the sump off.
Whats a good way to flush the engine out, im possibly thinking the engine is full of sludge as im getting low oil pressure.
1kz te oil pressure relief valve
Re: 1kz te oil pressure relief valve
If it's full of sludge, you'd be better taking the sump off anyway.
Have you tried checking the pressure with a gauge yet?
From memory the relief valve is externally accessible (I'd have to check on a motor at work to be sure).
Just had a look at the manual and the oil pump pressure relief valve is on the RH side under the alternator and above or behind the bottom coolant pipe, it is a plug with a sealing washer, a spring and a piston. The plug is on the side of the aluminium oil pump front housing. I don't think this will be your problem.
GOOD LUCK, IF IT WASN'T FOR BAD LUCK SOME PEOPLE WOULDN'T HAVE ANY,
FITZY.
FITZY.
