FS: Blizzard gearboxs and full PTO winch
Andrew1706
Post by Andrew1706 »
Have two blizzard gearboxes that are no longer needed:
1) Vacuum activated 4WD type - this one may need to be re looked at as I don't think I put it together well
2) 2H-4H-4L activated 4wd type
Also a full PTO setup from the gear in the back of the gearbox, the bracket thingo, the chaindrive thingo, shaft and winch. Winch needs 4x bolts where the shaft goes into the winch itself. Free spool has seized so needs some work to loosen it up. No cable.
Also might as well list the 2LT from the Blizzard as well, very early type, blew white smoke on start up but never when running. Surface rust all over, unsure of head but would suggest a strip down anyway.
