common rail diesel performance chips opinions
sig
Jeep Jeep
Post by sig »
hi guys as the title says who has experience with these and are they worth it and what brand to go for .and what do they do!all the blurb says more power plus better economy .this sounds to good to be true.have bought a new (to me) hiace 4wd van with 2.5 common rail turbo diesel but could do with more power ( as always never enough power)cheers sig :)
badnuz
Re: common rail diesel performance chips opinions
Post by badnuz »
we do the steinbauer chips, and unlike any of the others it controls fuel electronically, all the other"chips" raise the fuel rail pressure....
http://www.steinbauer.cc/neu/index.php?special_id=car_select&car_maintype=1&car_brand=379&car_type=8247&car_engine=17115&x=1&y=3
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Diesel Pumps in Sockburn Chch sell Steinbauer as well. If Scott sells this brand, then it will perform well.
Check out; http://www.dieselpumps.co.nz/products.html
Contact details;
http://www.dieselpumps.co.nz/contact.html
badnuz
Post by badnuz »
yup, Scott is one of our Steinbauer agents, we also sell them thru the ARB dealers around the country..
the modules are made in Austria but tuned in Aussie and Here to suit out lack-lustre fuel. in trucks and tractors they are getting on average 10% fuel saving and generally spend less time on the road/paddock...
we sell lots of D4-D for the new Hilux and for the D40 Navara, they go from 126kw to over 150kw and they go great!! if you add a decent exhaust and air intake (ie good filter) then you get even more bang!!
DaveM
Post by DaveM »
These are one of the most common for the guys running Patrols in oz, and they swear by them.
fweddy
Post by fweddy »
We have one of the new 3 litre common rail Hiaces (2008). No where near as nice as our old 1kz powered van (1998).
The old one had a nice even power range, but the new one loves to be in the 2.5-3.5k rev range or it doesn't bother performing. You have to do much more planning for over taking etc, the other one was a nicer van to drive.
This one's ok for around town but we do a lot of long haul work.
I understand the hiaces are set at about 90kw, and the hiluxs and prados are more like 120kw.
Can a hilux/prado chip go in? does it improve it much? what other options? what sort of costs?
NZ4WD Mag have reviewed them a couple of times...., may still have the mags.... will have a look..
sig
Jeep Jeep
Post by sig »
looks good but 2000 dollars!!!!!!!! :o :shock: .500 bucks for the other ones sounds better :roll:
badnuz
Post by badnuz »
the steinbauer will help reduce the lag that common rail diesels have, the power comes on earlier, as does the tourque...
see this graph for the 2.5td hiace chip:
http://www.steinbauer.cc/neu/pdf///STEINBAUER_aus__Toyota_Hilux_25_D-4D__1204_75_kW_1.pdf
Sig, the reason they are more expensive is they electronically enhance the fuel delivery, not force more fuel thru... the unit has many features, it doesn't run at idle, cuts out before redline ( to save EGT) and even cuts back the extra power if held at constant full throttle say going up a hill at 2500RPM, thus also keeping EGT at a normal level. ALL the other modules just push more fuel in, and considering common rails run at 28000psi already, more forced thru isnt ideal........
badnuz
Post by badnuz »
fweddy wrote:We have one of the new 3 litre common rail Hiaces (2008). No where near as nice as our old 1kz powered van (1998).
here is the graph for the 3ltr D4D Hilux/Hiace
http://www.steinbauer.cc/neu/pdf///STEINBAUER_aus__Toyota_Hilux_30_D-4D_126_kW_1.pdf
sig
Jeep Jeep
Post by sig »
they look like the ducks guts but i cant justify 2k
GETNLD
Post by GETNLD »
did you end up getting the $500 one? if so what was it like?
sig
Jeep Jeep
Post by sig »
yep bought it and it made a noticable power difference ,still get about 550kms out of a tank of diesel as well.made it from a slug into a faster slug
GETNLD
Post by GETNLD »
who what where?
sig
Jeep Jeep
Post by sig »
GETNLD
Post by GETNLD »
cheers sig, but ive gone to the dark side and got me a nissan now
sig
Jeep Jeep
Post by sig »
thats alright ,eventually you grow out of it :lol:
Return to “Tool Shed”
