caliper rub?
Sausage
caliper rub?
Post by Sausage »
Just got some new new wheels and tyres for my truck and put the first one on the front and the inside of the rim touches the top of the caliper? once done up tight i cant turn the wheel any thoughts? wheels came off a 1994 four runner and now on a 1995 surf kzn130 so assume they have same breaks and running gear so didnt think there would be a problem......
any thoughts?
Re: caliper rub?
er wrong offset, ie not enough
Sausage
Re: caliper rub?
Post by Sausage »
maybe but comming off a four runner assumed they would be fine as same running gear? and on the inside of the rims there is a line all the way round where the caliper as worn a mm or so off so maybe was a problem in the first place on the four runner until a bit had shaved off?
snork
Re: caliper rub?
Post by snork »
you would think they would be the same, what offset did you get?
a small slip-on spacer?
Sausage
Re: caliper rub?
Post by Sausage »
sorted! had a look at the truck they came off and the top of the calipers had been attacked with an angle gringer only a mm on 2 spots where it touched, so attacked mine took a bit off and presto!!! they are 75mm off set but all sorted now cheers guys
tallsam66
Re: caliper rub?
Post by tallsam66 »
YOu have got rims off a solid axle hilux...not an IFS....they need different offset wheels.
Sausage
Re: caliper rub?
Post by Sausage »
nope they were off a ifs four runner lol so yeah
kaney
Re: caliper rub?
Post by kaney »
tallsam is correct they are designed for a bean axle hilux or similar, ideally you need other rims rather than weakening your calipers. but you must be happy with it.
for future reference IFS wheels will fit the beam axle trucks but beam axle wheels wont fit IFS without spacers. (for ROH TRAK II or similar)
Lets just hope the wof man doesn't see your calipers when it comes to wof time
toymota thats stock standard.
skidtoy
Re: caliper rub?
Post by skidtoy »
yea mate wrong offset (backspacing) i run a mag and tyre shop so see alot of problem like you have...you have to factor in if your out 4wdn and ever hit the rims hard on something your going to buckle them enough to rub again and then your stuck in the middle of no where...you are really wanting a et0 wheel or even negative to get abit wide track also.
tallsam66
Re: caliper rub?
Post by tallsam66 »
Also if you get wheels with more offset youll have less rubbing on the inside when you articulate & steer full lock.
skidtoy
Re: caliper rub?
Post by skidtoy »
you really want atleast a et of -13 or lower for 7inch,-20 or more for 8inch,-44 for 10inch rims...these fitment will be best suited to the size tyres etc will want to be running on your truck.
you just dont really want to get stuck somewhere with a wheel jammed up...you'd be surprised at even what your wheels and hubs will pick up when your driving through mud,it wont take much in the way or rock,sticks/logs to jam it up also.
