When i first turn the key on the 4wd light comes up on the dash but when i start it and put it into 4wd the light does not come on can anyone tell me wot could be rong.
1995 bighorn 4wd wont ingage.
Hi there i have a 1995 bighorn when i go to put it into low or high 4wd it does not ingage the front wheels,
Re: 1995 bighorn 4wd wont ingage.
does any check lights come up?.
isnt the front vaccuum operated front diff?
if so could be a faulty solenoid, broken line etc?
does it make any clicking noises if you drive on? on my mu with manual hubs it wouldnt go onto 4wd, and i figures that all but 1 bolt from front driveshaft had come loose and fell off, and last one just broke - Which then hit the gearbox with some force and made a little hole in it.
Hi there thanks it was the vacum line on the front diff
sprey wrote:does any check lights come up?.
