Removing speedo needle on 70 series
minimun
Post by minimun »
How do i get the needle on my speedo off?
share force doesnt do it (its a toyota) so is there a special nack to doing this?
sig
Jeep Jeep
Re: Removing speedo needle on 70 series
Post by sig »
more force
Do you need another speedo?
minimun
Post by minimun »
depends on price
Let my last full dash go for 30 bucks which im starting to get depressed about
Is it anything like this? 12 or 24v?
The petrol one is in the parts pile to be used and not avaliable :D :D :D :D :D
Got 2 or 3 spare if it helps....
minimun
Post by minimun »
yeah thats the one. Mines the old version without the turbo lights etc. 12 volt. How much to part with one?
Will dig them out and get back to you :wink:
minimun
Post by minimun »
Cheers Jerry
Has anyone removed the needle from their speedo before.
mazdamike
Post by mazdamike »
use 2 forks and lever down with base of forks on the little screws eather side and it should pop up ond off hope that helps
minimun
Post by minimun »
mazdamike wrote:use 2 forks and lever down with base of forks on the little screws eather side and it should pop up ond off hope that helps
Bloody brilliant
Hopefully you read this jerry before you go basement bashing to find those dashes because sorry mate i dont need one. Will keep it in mind however incase it goes for good next time
