Hi, I have a TD27 with a leak from the injector pump, im looking at replacing the top seals and see what happens rather than paying hundreds to get the whole thing reconditioned. Is there anything to look out for doing this job?
TD27 Injector pump leak
- Bush Crasher
Re: TD27 Injector pump leak
2 main things are to make sure you put the throttle cable arm back in the same place and and you have to be carefull when you put the govenor cover back on as there is an arm you have to slide forward with something thin as you lower the cover.
Send me an email and I will send photos etc
lesday@wn.com.au
lesday@wn.com.au
