http://www.trademe.co.nz/Browse/Listing.aspx?id=288721048
I'd like $4500.
Buy My Surf
- mike
- Last minute Mike
Re: Buy My Surf
Also the truck has a push button manual controller for the trans that I designed and built myself so you can have any gear at any time, also with manual control of the lockup clutch. Goes back to fully auto at the flick of a switch.
I'm only interested in this because i already have a surf and this would be the best thing for towing. A few people on here would love to know how to do this. Any chance of a thread on how to do it
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Re: Buy My Surf
mike wrote:Also the truck has a push button manual controller for the trans that I designed and built myself so you can have any gear at any time, also with manual control of the lockup clutch. Goes back to fully auto at the flick of a switch.
Yeah I was originally going to put a few of these together and sell them.. manual lockup clutch control is as simple as a switch as most people know, tiptronic style gear change requires a bit of electronics.
I'll try get around to making a kit.
Re: Buy My Surf
forgive my lack stupidity but what is a lock up clutch? why is it a good thing or not? and how do you do it?
Re: Buy My Surf
Sausage wrote:forgive my lack stupidity but what is a lock up clutch? why is it a good thing or not? and how do you do it?
Most torque converters in automatic transmissions have a seperate mechanical clutch that is engaged at cruising speeds to eliminate the losses (heat) that occur as part of normal operation.
This is normally controlled by the auto trans computer, however it is nice to have manual control over it particularly when doing long hillclimbs and/or towing, as you can engage it at lower speeds than normal to lower your revs and lower the heat, heat being the enemy of an auto trans.
Re: Buy My Surf
$4400..
Re: Buy My Surf
$4300.....
