Hi Yah All
Where's a good place to buy mud flap material ie conveyor belting?
New or used.
Need to add some on the Cruiser, sick of throwing mud all up under the guards / sills...etc etc.
Calvin
Mud Flap material WTD Auckland
Re: Mud Flap material WTD Auckland
Para rubber carry a good range of rubber stuff.
Hi calvin there is a place in Manukau, I got some offcuts last year, and at a good price. Will look up the place and get back to you
Mike
Mike
para doesn't do conveyor belt from what I can tell, the para stuff doesn't have the fibre reinforcing like conveyor belt. You can get second hand belt from places that sell it a lot of the time too. Otherwise it can be expensive if your not careful.
Para may be able to source conveyor rubber perhaps if you ask but para here had no idea what I was on about.
What thickness are you looking for and how much (HxW) do you need. I've got a roll of 10mm odd thick stuff here to make Mud flaps for the surf, but more than what I need
LR110 ..... LJ50 project
i have got a fear bit of this at work mate if you give me a ring tomorrow i will see what i can sort out for you.
work number is 9767309 or mob 0212440914.
Phil
Phil
Cheers Phil Will Do !
Calvin
Calvin
