Suzuki leafs
brakes-shocks-lockers-etc
Phillip
Suzuki leafs
Post by Phillip »
My suzuki has 3 leafs in the suspension and is hard as, would it be ok to take one leaf out and only have 2 :?:
suzukisam
Post by suzukisam »
Should be fine, the early nineties samurais only had two leaves in the front. They tend to sag a bit quicker, but then they only really last about 100,000k anyway so go for it and start saving for the next set...just watch the rear if you take too many leaves out of the rear, i did and i got a bit of axle wrapping which dented the shock body. I fixed it by putting half leaves in acting as traction bars (like the dragsters have)
cheers lester
Lester
Waikato NZ
The Last Samurai
