D21 terrano GB/TGB oils?
For all Nissan related topics
Nivapulledout
Post by Nivapulledout »
Hi guys my dad is changing his terrano's oils and is wanting to know what oil to use.
I thought both gearbox and transfer box should be using the same spec oil. But the wksp he gets his oil from said the transfer boxs uses something different.
would be good to see if you guys are using the same oil in both
thanks
Craig
aroma
Re: D21 terrano GB/TGB oils?
Post by aroma »
from memory gear box and transfer were the same but i had lsd in the back
google it :D
toominator
Post by toominator »
What year, engine and trans type does it have?
I'll check on our castrol software at work tomorrow.
Otherwise you can use a slimmed down version by using the following link
http://www.datateck.com.au/lube/castr_nz/default.asp
Nivapulledout
2.7t manual box and think around a 95. thanks for that.
toominator
No worries, this is what castrol says to use
Manual trans: Castrol VMX - 4L
4wd transfer: Castrol TQ-DIII - 2.2L
It looks like the transfer box must have changed with the 92 model because pre 92 takes VMX in the transfer box too.
Nivapulledout
hay thanks for that. will let him know, another great job from the ORE boys.
