Brought myself a surf
Militaris
Post by Militaris »
Over the weekend I brought myself a toyota surf, at the moment it appears to be a fairly standard 1993 3L diesel surf. Given it a few basic test runs and played with it on a few beaches and across several rivers. Due to the warranty issues I would have to wait a while before modifying it in any serious way.
warranty aside, I do not really know where I should start with the mods. I am planning on removing the runner boards from the side, because they trap dirt and water and serve no real purpose.
Been thinking about installing a snorkel (would have to see how it would affect the warranty), and purchase a tow rope, fire extinguishers and other tools which might be useful. Maybe a bull bar although not to sure how necessary it would be.
I also noticed that it has dual batteries, are the two batteries used at the same time for everything, or is one just for starting the engine while the other is used for the electrics? Seems like a lot of battery power.
SupraLux
Complete Bastard
Re: Brought myself a surf
Post by SupraLux »
Militaris wrote:Over the weekend I brought myself a toyota surf, at the moment it appears to be a fairly standard 1993 3L diesel surf. Given it a few basic test runs and played with it on a few beaches and across several rivers. Due to the warranty issues I would have to wait a while before modifying it in any serious way.
Yep, those buggers will look for any reason to get out of paying for anything
Militaris wrote:warranty aside, I do not really know where I should start with the mods. I am planning on removing the runner boards from the side, because they trap dirt and water and serve no real purpose.
:?: No, leave em on there... they'll stop the sills getting damaged to a certain extent, and scratched and they help the wife/gf get in the truck... they moan a lot if its too hard to climb in to :P
Militaris wrote:Been thinking about installing a snorkel (would have to see how it would affect the warranty), and purchase a tow rope, fire extinguishers and other tools which might be useful. Maybe a bull bar although not to sure how necessary it would be.
Yes, get the recovery equipment, and check first then install a snorkle. I duobt that would be a warranty issue since they provide cleaner air into the engine. Don't worry about a bullbar, unless you're planning to bush bash it or fit a winch.
Militaris wrote:I also noticed that it has dual batteries, are the two batteries used at the same time for everything, or is one just for starting the engine while the other is used for the electrics? Seems like a lot of battery power.
Starting only. Toyotas "cold weather starting" option... two batteries in parallel.
Hey - I wonder if the warranty would allow a SAS? :D
Steve
Militaris
Post by Militaris »
True the boards do offer a bit of protect, but they still resist the flow of water during river crossings. Also by removing them it helps keep the girlfriend agile. I might replace them with rigid metal mesh which would be less of a barrier for the water, but still provides easy access for midgets.
Mmm a SAS is fixing a manufacturers flaw so it should be allowed... but something makes me think the warranty company would see things differently.
wjw
Post by wjw »
Militaris wrote:True the boards do offer a bit of protect, but they still resist the flow of water during river crossings. Also by removing them it helps keep the girlfriend agile. I might replace them with rigid metal mesh which would be less of a barrier for the water, but still provides easy access for midgets.
make sure they are strong enough to walk on.... otherwise you'll get very wet hooking strops in the mud/river
Who knew Prados could fly?
Jafa
Post by Jafa »
:lol: u really are the "King of the SAS" aye, but dont waste your time on boring old Surfs etc, I want to see you SAS a Austin Princess :o something just a little different to match your slightly eccentric personality!! :geek:
021 273 9942
jafa@inspire.net.nz
JTop
Post by JTop »
there was a LADA available somewhere wasn't there
J Top
SupraLux
Complete Bastard
Post by SupraLux »
Jafa wrote:dont waste your time on boring old Surfs etc, I want to see you SAS a Austin Princess :o something just a little different to match your slightly eccentric personality!! :geek:
http://www.offroadexpress.co.nz/modules ... 7749#17749
Someone has raised the bar... I have work to do! :shock:
Sorry about the thread HiJack... discuss this on the thread linked above...
...Oh, and if you want solid bars that won't affect your warranty, will take any abuse you can throw and won't really do anything to the water flow in rivers have a look at the ones I make... there, now officially not thread-jacking :)
Steve
SupraLux
Complete Bastard
Post by SupraLux »
JTop wrote:there was a LADA available somewhere wasn't there
J Top
I could do a conversion on a Lada... turn it into a 4WD :lol:
Clint
Post by Clint »
Some good solid tow points front & back - 10 000lb rated hooks - are a good start. Makes life much simpler & safer when 4x4ing with mates. If you decide to join a club they'll be mandatory anyway.
Clint
albundy
Rolly Polly
Post by albundy »
Don't worry, it is only and illness and you aren't responsible. It's probably a behavioural problem from unresolved chilhood trauma :lol: :lol:
Nah seriously, have fun with it and modify 8)
Al
hiriklux
Post by hiriklux »
:shock: :shock: he didn't buy a nissan al :D :D :D
PAID
Post by PAID »
if he does the snorkel, will he have to do the diff breathers as well?
SupraLux
Complete Bastard
Post by SupraLux »
They are independant of each other... although if you're planning to play in rivers then high-level diff breathers are a very good idea since they help keep water out of the diff oil... saves money, time and your ring&pinions :)
Steve
PAID
Post by PAID »
SupraLux wrote:They are independant of each other...
Steve
yeh knew they were.. figured there;s little sense in one without the other.. just ask my boy fitzy about the Red Dragon.. snorkel looks great, but his diffs are shot ;)
