Fitting larger tyres do I need to lower my diff ratios?
brakes-shocks-lockers-etc
suzukisport
Post by suzukisport »
Running 32 simexs on with toyota 4.1 ratio diffs, do I need to lower my gear ratio if I fit 35 simexs. Running a commodore motor.
MNC
Re: Fitting larger tyres do I need to lower my diff ratios?
Post by MNC »
suzukisport wrote:Running 32 simexs on with toyota 4.1 ratio diffs, do I need to lower my gear ratio if I fit 35 simexs. Running a commodore motor.
Not sure what commy motor you are running but I'm assuming a 6 cylinder which will spin your 35s with the 4.1s no problem.
suzukisport
VN 3.8L V6 Commodore motor, in a Suzuki Vitara, running prado diffs
