rover v8 into jeep
rover v8 into jeep
i have an old mahindra jeep that i would like 2 repower with a 3.5 rover v8. is there an adaptor plate i can buy. so i can use the jeep gearbox. it currently has a 2l ford cortina engine in it, but we have had nothing but problems. so its time for a change.
Re: rover v8 into jeep
91 Surf white, 33inch mudstars 10s suspension lift body lift 2.4 turbo manual running 15 pounds manual hubs 12000 pound winch lots of spot lights and a cb
NVR 2 HI wrote::roll: buy a toyota
another comedian joins ore ....
v8 tj...luvs the gas......
MUDZILLA1 wrote:i have an old mahindra jeep that i would like 2 repower with a 3.5 rover v8. is there an adaptor plate i can buy. so i can use the jeep gearbox. it currently has a 2l ford cortina engine in it, but we have had nothing but problems. so its time for a change.
Yep it used to be quite a common conversion, not really sure where to get one from sorry.
so you can have the motor fluck out?
My old CJ4 had a rover V8 in it, but it was set up with the rover gearbox and transfer. Firewall was pushed back about 4 inches so the driveshafts ended up being similar lengths, meant the two rearward spark plugs were a pain to get at to remove.
