How do I do this? I tried on a bleed valve half way down the fire wall but it felt like it was taking for ever.
I have read on other forums that its gravity fed if you undo the valve on the slave. Where is the slave is it right underneath or the one that I was using half way down the fire wall?
Any help would be great
Thanks
Ray
Series 2 clutch bleed
- Landy Rover
Re: Series 2 clutch bleed
The slave is the cylinder that activates the clutch release bearing, should be on a bracket on side of gearbox bell housing. Later boxes had it on the left lower side. They are pricks to bleed and Ive sometimes resorted to using a huge syringe full off fluid going in from the slave nipple.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
