Hi, I am thinking about putting a Commy V6 in my Surf and want to retain the auto box but don't want to fork out for the Marks adapter for the transfer case, so was thinking of separately mounting it, does anybody know of a flange or yolk that has the correct spline for the input shaft of the transfer box.
Or is there another option.
Thanks in advance for any suggestions .
Tim
Hilux/Surf Transfer Box Input Shaft Spline
Here t'is:
http://www.ottindustries.com/divorcetoyota.htm
Over The Top make an adaptor to turn the Toyota transfer case into a divorced case so you can make a short driveshaft and run it separate.
What size tyres are you going to run? I've heard the Holden auto is a slushy pig with big tyres and a surf... nothing first hand, just what I've heard... might be worth looking into tho...
Steve
Steve
