idler arm brace,is it road legal
Hi all,I am looking at getting a idler arm brace and possibly slider plates for my terrano.Does anyone know if I need to cert them?.Truck is standard apart from 31s,so dont want to spend $350 to put on a $150 dollar part.Any help would be appreciated.Cheers
Re: idler arm brace,is it road legal
I'd argue that you havn't modified anything, just added bolt on accessorys that help keep the truck warrentable after a days outing. I'd fit them, then removal for a warrent is an option if need be. You will most likely be replacing idler etc for each warrent anyway if you dont fit them. IMHO
Dont require cert
I have both on my Terrano and I can confirm that they do not require a cert. You will have no trouble with a WOF either as they are a "bolt on" accessory. If they were welded to the chassis, well that's another issue.
Ph 0212078472
Ph 0212078472
Thanks guys,thought that would be the case but wanted another opinion.Just got a Terrano to tow my boat but am getting seasick driving both haha,hoping a brace might help(have done ball joints and tr ends).Thanks again
seadog wrote:Thanks guys,thought that would be the case but wanted another opinion.Just got a Terrano to tow my boat but am getting seasick driving both haha,hoping a brace might help(have done ball joints and tr ends).Thanks again
What exactly are the symptoms you are suffering?
What part of the country are you from?
Ph 0212078472
Ph 0212078472
Hi again,I am in Invercargill.When I am on a long bend it swerves a bit(like towing a trailer thats swaying around is the best comparison I can think of).Front left tire is wearing on the outside also.Hopeing a new idler arm and brace will tighten things up a bit(idler arm not looking to straight at moment).My theory is that if I stop idler moving around it might stop everything else wearing out.Truck is just a tow/hunting/holiday wagon,didnt cost a lot and I dont want it to cost a lot to keep,so looking for a "ounce of prevention".Am I on the right track??
