93 Hilux Surf - How Big Can The Wheels Be??
Hi, I have a 93 Surf, with a 2" Old Man Emu suspension lift (Torsion front, spring rear). Question is, how big can the wheels be? 31's look OK but can I squeeze in a 33? If not, what about 265/75 x 16? I'm looking to buy some Mickey Thompson alloys and tyres, so can go for either 15" or 16" wheels and get rubber to suit.....any ideas....
Re: 93 Hilux Surf - How Big Can The Wheels Be??
You will be able to squeeze in 33 ok.... but you might get a little rubbing on full lock or articulation.
As you have a surf if you go for after market wheels be very careful you get the right ones.You need a different backspace to a hilux with solid front axle to clear the front brake calipers.
ive got 15x8-28 with 32x11.5 on a 95
had to do body lift with the rims so as not to rub
