i am after a ball joint flip for my 1993 swb pajero
i have a 1993 swb 3.0 petrol pajero and am wanting to do a lift on it, any tips and pointers thanks.
Re: i am after a ball joint flip for my 1993 swb pajero
are you looking to just fit bigger tires? or get more ground clearance... because a body lift is easier and might be all that you need.
Current ride: 2002 L6 4.0 Jeep Wrangler
Ya gotta watch out with bodylifts aye, seen a few broken body mounts due to bodylifts.
Cheers Daniel
Cheers Daniel
adimw2 wrote:are you looking to just fit bigger tires? or get more ground clearance... because a body lift is easier and might be all that you need.
just after the ground clearand already have 33x13.5 on it, where would a get a ball joint flip from?
You don't 'get' a ball joint flip. Do a search and you will find, you flip your ball joint. not extra parts needed.
And it won't give you more ground clearance.
If you have money to burn mate, this is for you.
http://www.trademe.co.nz/Browse/Listing.aspx?id=313535487
Otherwise, its easy enough to do it yourself
just check out this thread.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?t=2159
Pretty sure NJV6 did it in here somewhere
