Wanted : VL Commodre Fuel Pump
UBZ
Post by UBZ »
Wanted as per tilte an External Holden VL Commodroe Fuel pump or similar for an EFI engine conversion .
Cheers Chris.
gimmemud
Re: Wanted : VL Commodre Fuel Pump
Post by gimmemud »
I'm almost certain i've got one at home cause I'm now using the in tank pump. Will get my sister to have a look. Think i got quoted about $215 from bnt for a new bosch 044 pump (same pump) if you're looking to buy new
wopass
Post by wopass »
i used a 5.0 VN commy pump when i did the conversion on the phaatsun. the V8's had an external in line pump and the v6 had in tank.
just another option for you :wink:
