CV grease nipple
brakes-shocks-lockers-etc
Heath
CV grease nipple
Post by Heath »
Saw on a dvd a grease nipple in a stub axle that allowed grease to be pumped into a cv (just remove the outer hub cover I guess) and there was some sort of spring loaded valve on the hub(turny swivelly thingee :wink: ) so the pressure didnt pop any seals. Looked like a good idea, but would be a bastard drilling a tiny hole all that way (specially if it was hardened) :mrgreen:
sibainmud
Re: CV grease nipple
Post by sibainmud »
Easy with a lathe and a bunch of long series cobolt drill bits.
Spin the CV in the chuck, and drill away. The drill won't wonder because the spinning shaft keeps the drill bit centred :wink:
Heath
Post by Heath »
Well bugger me, as simple as that. I guess there will be piles of these turning up now. I wonder how it would affect the strength of the stub axle though. Not much I guess, but it would depend on the dia. of the hole.
Bulletproof
Post by Bulletproof »
The CV is not normally a problem. Once it is filled it doesn't need topping up that much. It is easy to remove the bung and still use a grease gun
The main problem is the top king pin bearing because it goes rusty.
I have put a grease nipple in the top in the middle of the 4 bolts to grease the bearing which also goes through to the CV and it works well.
Cheers Richard
Never say die, up man and try
Heath
Post by Heath »
Bulletproof wrote:The CV is not normally a problem. Once it is filled it doesn't need topping up that much. It is easy to remove the bung and still use a grease gun
Cheers Richard
Yeah thats how I have done it in the past too. This one seems a little complicated...
