4x4 light flashen in 2wd
benorange
Post by benorange »
i got a 92 pajero and the front wheel lights are flashing on the dash for the front wheels when it is in 2wd. i even tryed backing all the way up the drive. what could the prob be
northland_pajero
Re: 4x4 light flashen in 2wd
Post by northland_pajero »
Mine sometimes does it, putting into all wheel drive, till the lights go solid then back into 2wd sometimes fixes it.
or it could be the vaccum switch.
tga_4x4
Post by tga_4x4 »
More than likely the solenoid is stuffed, I had this happen to mine, there is 2 solenoid on the driver inner guard follow the tubes you will figure out which one it is, from memory you can swap them over to check them but i got a spare set from pick a part and swapped them over and she is all good now, the other thing to check is there are no vacuum leaks to the reservoir on front diff, you cant miss it either
krokkie
Post by krokkie »
Have a read here:
http://4wd.blogeasy.com/
I used it when troubleshooting my flashing lights. Mine turned out to be my solenoids.
Return to “Mitsubishi”
