Wanted Chev to Toyota bellhousing
- ClassicCruiserSpares
- Sausage Shack
Just woundering if anyones got a bellhousing to bolt the 350 chev to the 40series Landcruiser 4speed lying around? also the front engine mount for the 350 to go into the 40series
Re: Wanted Chev to Toyota bellhousing
Ive got a front engine mount for a 350, not too sure if itll bolt straight onto the factory mounts or not, was a bit hard to tell with the set up in the 40 it came from. Im going to make different mounts for my 350 so wont need it
Didn't barbie drive a jeep??
- Sausage Shack
Are you able to up a pic or pm me with a pic? Thatll be great if its the rite one.
Yeah ill find it an take one tomorrow. It bolts to the front of the engine.
- Sausage Shack
Awesome mate cheers, yea i need the one that bolts to the front of the motor, but most of them also go straight onto the petrol chassis mounts, but if yours is slightly different i could just make new mounts to suit.
I used to have one of those front engine mounts in my flatdeck but it twisted with the engine torquing then kept on breaking bolts after that and the engine kept on falling over, use the chev engine mounts and make up new brackets if you can or better still make up some captive engine mounts
mine has a front mount but its a home made one and looks rangi as...hasnt broken yet so must be ok
wopass wrote:mine has a front mount but its a home made one and looks rangi as...hasnt broken yet so must be ok
should have got me one of those ones in the first place then I wouldnt have had so many problems
