tow hooks
Re: tow hooks
Yup, use the factory one, its pleanty strong enough. And you can also cut the tie down point off the other side and bolt on another in its place.
Re: tow hooks
i think mine must not have one cos the only thing that is close is the small one welded to chassie it looks like if you pulled on it with a piece of string it would break the welds
the places i get stuck take a lot of getting out of so want strong rated hook
Re: tow hooks
You are quite right, the factory hook is not suitable for recoveries.
I will not snatch anyone without a proper hook setup, I'll winch them instead. I have seen the damage a broken tiedown and strop can do.
I have cut off both factory tie downs and have a piece of angle iron bolted (with rated bolts) to the chassis with pipe sleeves inside the chassis for strenght. The rated tow hooks are mounted facing upwards so the strop won't fall off.
Re: tow hooks
Camshaft wrote:You are quite right, the factory hook is not suitable for recoveries.
could you take a photo of how your set up is please
Re: tow hooks
please... i would be keen to see your setup as well
Re: tow hooks
ok so made good strong bumper wiht tow hooks bolted it all up then tested it by pulleig hedge out. i now broke all the welds on oneside and bent it all up and cracked on the other so how i have to fix the bits that mitsi rushed and did not weld proper
Re: tow hooks
A GDI with hook mounted as described.
You can see my hook here.
I will take another photo tomorrow.
