Hilux or Surf Transfer Case Mounted Drive Shaft Brake
Moderator: Vendors
Hi,
I have got a couple of Transfer Case Mounted Drive Shaft Brake assembly for sale, it is new.
Cost is $325 plus freight from Hamilton.
PM me if interested
See below for details
Tim
Product Description.
Need an E-brake? Have bad cables, or a disk brake conversion? We have the answer with our simple and affordable Toyota T-case E-Brake Kit. It can be installed in under 1 hourand is fully bolt on. You do have to remove the t-case output flange in order to clearance the dust seal cover.
The E-brake kit reuses your stock e-brake cable up to the frame mounted e-brake arm located in front of your fuel tank. The t-case e-brake is constructed of laser cut and tig welded CNC formed 1/4 plate steel. Includes all parts you will need for installation, comes with instructions.
Fits all 4 cyl. Toyota t case's. Bracket’s are designed with a skid plate below the caliper and the ends are formed and tig welded to the main plate. The box style mount helps ensure no flexing of the t-case and caliper mount. This helps eliminate wear on the pads as well as possible stress on the t case itself. May not fit with all aftermarket t-case crossmembers.
PM me if interested
Tim
Re: Hilux or Surf Transfer Case Mounted Drive Shaft Brake
hi m8,could you pls put up some photos.
thanks andy
thanks andy
- skid
- Tyre Man
does this mean mine is ready for pick up????????
Hi Skid,
Thanks for the pictures, cheers for that.
Hi Jared,
Not quite, got an email earlier in the week saying that it should be available Tues or Wed, then got an email on Fri saying the containers arriving in Tauranga today , so will hopefully have stuff by middle of next week.
The thread is just to see if there is any interest in the extra one I bought.
Tim
Hi Jared,
Tim
Bump,
See first post.
PM me is interested.
Tim
See first post.
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
- muddyhilux
will let you know asap,pretty sure my brother n law is keen to grab it as this will work perfect in his next stage of mods
Would one of these fit a 40,60,70 xfer box.. particualy the 70..? as I have one and am looking at doing a disk brake conversion on my 87 series landcruiser..lol..
Bump.
See first post
PM me if interested
Tim
Have only got one at the moment which maybe taken.
Just seeing if there is any interest for me to get some more in 3 or 4 weeks time.
Regarding fitting a Landcruiser, very much doub't it would be a direct fit, but you may be able to adapt.
Tim
See first post
PM me if interested
Tim
Tim
Bump.
Have got a couple more
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
Have got 1 left at the moment
See first post for details
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
- jonossiksilvia
do this work with an auto transfer box? does it work with the electric motor 4wd transfer? really interested
thanks
thanks
Hi,
I do not know if there is any difference in the transfer case at the back where the brake bolts on.
I could send you a template of the bolting flange so that you check it against your transfer case.
If you PM me your email i can send a scan of it and you can then print it out and check
Tim
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
- KIWI_TERRANO
Are these warrentable??
Looking at one if handbrake for my disc conversion dont work great
Yes as far as I am aware, a few guys on here have fitted them, pretty sure on road legal trucks.
Similar to old Landrovers and Suzuki's
Tim
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
Bump.
PM me if interested
Tim
PM me if interested
Tim
