makeing my 413 wider???
hey i see some people have theyre wheels sticking out further than normal,what is involved in doing this,just wider wheels??my 413 seems very narrow and seems like its going to tip over when on an avarage slope.
if any1 can help please let me know.cheers
try this link .........http://www.4wheelonline.com/Categories. ... gationTree
or this.........http://www.rocky-road.com/kicksus.html
Im looking at some from this guy : http://www.trademe.co.nz/Trade-Me-Motor ... 285503.htm Just want to make sure its all legal first.
Im getting mine to stop my tyres rubbing at full lock.
Cheers, AJ
Cheers, AJ
callum007 wrote:or.. get on trademe. look up wheel spacers.. up to 29mm is legal.
27mm is the max legal width of bolt on spacers, or (depending how you read the LTSA rules) 10, or 20mm for slip-on spacers, although you have to have extended studs to use them.
I manufactured a couple of sample 6-stud sets a while back, but they cost around $300 to make a pair properly. Not just a simple ring and some bolts... I ended up swapping one set for a cool MP3 player for the MU and I run the other set I made on the MU... Never found anyone interested in paying that much for them... although I will make them to order. There are other ways to do it tho... for that money you could have all your wheels re-centred for better offset, or just buy some new whitespokes with greater offset.
Steve
I would get some 15 x 7 steel spoked rims. I think Mangel have a 0 offset one and I cant for the life remember the other brand do one 15mm more offset. Most tyre shops should be able to do them for about $80 each. This will help with some more width.
I use the mangel brand on my 410 with 31 x 9.5 x 15 handcuts, I could always do with more width but im in the process of getting bits together to put Rover running gear under my zuk so this should help immensly
You will be suprised how far you can push a zuk before it flops
But when it goes it happens quick
The things ya do in competition
ok thanks for the info,mite looking into getting some maybe even a set of 2nd hand ones.otherwise theese sound like wat im looking for.http://www.trademe.co.nz/Trade-Me-Motor ... 628732.htm
if any1 got an old set theyre keen on selling please let me know.cheers
just get them to call the wheel company and say they are going to be a set for competition, that avoids the stupid questions about them sticking outside your guards. mention that you want them out the guards...
nah theres not much margin in them. they cost about $55+gst each then the tyre comp wants a bit of markup obviously.
