hi all, i scored an old compressor and ripped off the switch and plumbed it all up and it wont work. it is always bleeding off air from the sensor thingy with the smaller tube input, on the wiring side what is required?? i have played around with wiring as in swapping neutral and phase on the compressor wire but nothing happens
any one that can help??
aircon conversion air pressure switch problems
DIRTY OLD HILUX
022 519 7700
022 519 7700
Re: aircon conversion air pressure switch problems
Show us a photo of your install.
I had a compressor once that would keep running. Played with the spring loading and it came right.
Calvin
Calvin
